TwinTurbo.NET: Nissan 300ZX forum - Re: Seated injectors into the rail by means of using cap?
Subject Re: Seated injectors into the rail by means of using cap?
Posted by hellraz0r1337 on June 21, 2012 at 8:13 AM
  This message has been viewed 289 times.
In Reply To Seated injectors into the rail by means of using cap? posted by Coldfusown on June 21, 2012 at 03:00 AM
Message oh i read on a different forum that thats fine as long as there lubed and seated some what. OK well ill just pull the plenum again and redo them. So you used the injector lube or a thin layer of oil? i just threw out my injector lube guess ill go purchase some more. And you really put the injectors in and push down somewhat and than they popped in?
And yea timings fine thats not even in my memory anymore.
