TwinTurbo.NET: Nissan 300ZX forum - Seated injectors into the rail by means of using cap?
Subject Seated injectors into the rail by means of using cap?
Posted by Coldfusown on June 21, 2012 at 3:00 AM
  This message has been viewed 292 times.
In Reply To Re: Injectors leaking posted by hellraz0r1337 on June 20, 2012 at 09:28 PM
Message I don't think you're supposed to do that. When I installed mine I lubed plenty and kind of twisted them slightly back and forth whilst firmly pressing in which worked well. Sounds like your timing belt would be okay though if you counted teeth and checked tension all should be good. Others will be more knowledgeable.
