TwinTurbo.NET: Nissan 300ZX forum - vacuum leak most likely cause. Definitely not
Subject vacuum leak most likely cause. Definitely not
Posted by doug8867 on June 20, 2012 at 1:51 PM
  This message has been viewed 146 times.
In Reply To please help posted by jaredc17 on June 19, 2012 at 07:47 PM
Message injectors with your symptom. Check all your medium and large hoses are connected tightly and or not bent on the lip, or cracked, specifically the throttle body and MAF hoses.
Also if you have a pop charger and don't have an undershield air turbulence can cause the stall or almost stall symptom.
