TwinTurbo.NET: Nissan 300ZX forum - Can you explain further? - not sure what's meant by a
Subject Can you explain further? - not sure what's meant by a
Posted by jzack on June 19, 2012 at 9:38 PM
  This message has been viewed 136 times.
In Reply To any z guru's able to help?? posted by Nismo300zx1990 on June 19, 2012 at 05:42 PM
Message good ignition wire for my fan? Do you mean a good place to get +12v that's only on when the key is turned? If so, the engine bay fuse box would be a good place to go? Once you have the +12v source identified, I'd use that to power a relay that then provides power to the fan.
This FAQ may also help - can be modified for your needs:
[ http://www.twinturbo.net/nissan/300zx/forums/technical/view/1036299/Update-Injector-Switched-Power-Line-Using-Fuse-Box.html ]
PS: Most find the the OEM pulley driven fan works better than aftermarket electric fans.
