TwinTurbo.NET: Nissan 300ZX forum - Fix the HICAS ball joint first. If it is still loose, which
Subject Fix the HICAS ball joint first. If it is still loose, which
Posted by Gordo 93TT Daytona on June 19, 2012 at 6:23 PM
  This message has been viewed 159 times.
In Reply To Re: Wheel bearing, outer tie rod, control arms posted by jonting421 on June 17, 2012 at 12:35 AM
Message by your discription sounds like both wheel bearing and joint are worn, then replace wheel bearing. Do both sides together.
_________________________________________________
