TwinTurbo.NET: Nissan 300ZX forum - issue with HID's
issue with HID's
Medallion Man
on June 19, 2012 at 10:11 AM
RonZ300 I have the same issue. My Idle sucks when I turn my
posted by JoshE300zxTT
on June 18, 2012 at 08:14 PM
have you thought about using a relay for the power for the HID's (straight from the battery)...
pick them up on ebay cheap....
http://www.ebay.com/sch/i.html?_nkw=h3+hid+relay+harness&_sacat=0&_odkw=hid+relay+harness&_osacat=0
that would eliminate any surge issues.
also check all the fuses for the lights and make sure the earths/grounds are good.
ground kit for the engine as well...
Tough one for the guru's (long and involved)
RonZ300 (Socal)
10:35:46 06/17/12
majority will say this belongs in tech
nissan300zxwork
11:06:30 06/17/12
I will, but had the idle problem years before i got the HIDs (n/m)
RonZ300 (Socal)
12:51:04 06/17/12
I'll be watching this one. Have an occasional problem like
arrowenterprises
12:40:52 06/17/12
double check your injectors. (n/m)
Summeronthechain (MN)
12:54:11 06/17/12
2nd. I was reading this and thinking the same thing. (n/m)
Polish
13:01:13 06/17/12
This, I had an occasional misfire on 6
BlackholeZ
13:05:30 06/17/12
unplug ur 02 sensors n see if it idles smooth.
Drk93TT
13:19:13 06/17/12
Thanks, ill try that. Also, same idle before and after injec
RonZ300 (Socal)
13:31:23 06/17/12
Where are your hid ballasts? Under your nose panel? (n/m)
pearlzed(toronto)
18:14:43 06/17/12
The fogs are beside the SMICs and HIs are in the engine bay
RonZ300 (Socal)
18:56:45 06/17/12
Im more concerned about the idle than the HID EMI (n/m)
RonZ300 (Socal)
18:57:59 06/17/12
JoshE300zxTT
20:14:51 06/18/12
issue with HID's -
Medallion Man
10:11:52 06/19/12
Thanks for the info! Ill check my translator. (n/m)
RonZ300 (Socal)
10:06:37 06/20/12
