TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Re: timing belt tension issue
Subject Re: Re: Re: Re: timing belt tension issue
Posted by hellraz0r1337 on June 18, 2012 at 2:32 PM
  This message has been viewed 185 times.
In Reply To Re: Re: Re: timing belt tension issue posted by MaxxAction on June 18, 2012 at 02:16 PM
Message Um ok I haven't even messed with my cas timing I figured I didn't need to adjust it cause I took off the whole arm and not the actual cas from the mount. Should i go purchase a timing light and set my car timing via cas? If so I have never used a timing light I know how they work but loosen the screws slightly on the cas and turn counter clockwise for retard right? So 15 degrees Btdc is where I wanna be? What's that look like on a timing light?
