TwinTurbo.NET: Nissan 300ZX forum - 1st thing I would do is double check all sensors/wiring
Subject 1st thing I would do is double check all sensors/wiring
Posted by Summeronthechain (MN) on June 18, 2012 at 9:30 AM
  This message has been viewed 179 times.
In Reply To Re: timing belt tension issue posted by hellraz0r1337 on June 18, 2012 at 09:26 AM
Message to verify you didn't forget to plug anything back in.
Also, make sure you don't have a vacuum leak from any of the charge piping.
If you are sure that is not the case, then yes, it sounds like your timing might be off a tooth. Redo the belt.
