TwinTurbo.NET: Nissan 300ZX forum - Mechanically, I'd be drawing at straws.
Subject Mechanically, I'd be drawing at straws.
Posted by PiotrC70 on June 17, 2012 at 2:43 PM
  This message has been viewed 228 times.
In Reply To Re: Seriously dude!!! First split second I would see that I posted by ceron801 on June 17, 2012 at 02:13 PM
Message It doesn't sound like a miss fire since the problem seems to go away when you rev. Although hard to see, you look like you have oil pressure so that's good. My first instinct would tell me run codes, verify timing, verify TPS, adjust as necessary. Get the quick stuff out of the way. Next, pull all the plugs, fuel pump relay and do a compression check.
btw, the closest Z specialist near you is Z1, they're 85 miles away. Based on your 2 video's, I'd tow the car there if you're not capable enough to start pulling the motor apart yourself.
1993 TT. R.I.P. 09.15.2010
