TwinTurbo.NET: Nissan 300ZX forum - Is it leaking brake fluid at the brake peddle plunger>>
Subject Is it leaking brake fluid at the brake peddle plunger>>
Posted by ZUL8TR on June 17, 2012 at 3:57 PM
  This message has been viewed 357 times.
In Reply To What do you mean by the master cylinder being sealed? (n/m) posted by Havoc300 (Chicago) on June 16, 2012 at 04:29 PM
Message The leaking fluid could be inside the brake booster and tuff to see. When car is cold and engine off press brake pedal several times till hard and press to see if pedal sinks. It should not sink, if it does there is a leak in master and/or elsewhere.
ZUL8TR in Orlando,FL
