TwinTurbo.NET: Nissan 300ZX forum - Front Brake Calipers Sticking After Rebuild
Subject Front Brake Calipers Sticking After Rebuild
Posted by Chickan on June 17, 2012 at 11:13 AM
  This message has been viewed 647 times.
Message I had a stuck piston in the Front Left caliper so I decided to rebuild both front calipers and install stainless steel brake lines on the front. I did not touch the rear brakes except to bleed them. Got everything back together, bled the system, and now both front calipers appear to be sticking/dragging a bit. On a slight hill the car will not roll backwards and after a short drive the front brakes were smoking hot.
The caliper pistons move in and out freely, I can compress them with my hands and less than 20psi of air is sufficient to pop them back out.
What else can cause the brakes to stick? Is there something I missed?
