TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: clutch fork no longer attached to anything in the xmission
Subject Re: Re: Re: clutch fork no longer attached to anything in the xmission
Posted by Medallion Man on June 16, 2012 at 5:39 AM
  This message has been viewed 1549 times.
In Reply To Re: Re: clutch fork no longer attached to anything in the xmission posted by 300zxttrob (Houston) on June 15, 2012 at 08:54 PM
Message this is a possible problem...
[ http://www.300zx.co.uk/forums/showthread.php?144203-Clutch-pivot-ball-failures&highlight=clutch ]
Gear selection problems can be caused by many issues but one that seems to rear its head occasionally is pivot ball failure. For many years now up-rated ones have been available and usually come part of upgrade kits, we always advise fitting these as part of any change upgrade or standard as its not worth the hassle later.
So here is a classic pivot ball failure with a little twist in the tail, the ball head breaks away but is often kept in place by the retaining clip, as a result the breakage can go unnoticed for a while however every time the clutch is depress the ball head is mashed in to the remaining pivot shaft until the lever arm slips sideways. In this case the input splines were very dry as was the crankshaft bearing, this had destroyed the spigot bearing and now the whole unit was compromised with the lever arms tilting over when the clutch was depressed and causing the release bearing to meet the cover plate at an angle.
All of this had damage from one small pivot ball, luckily in these case the clutch itself had been spared from any damage, due to the fact that the spigot bearing, bearing carrier and pivot ball were all dry suggests poor fitting practice when the clutch was last fitted, beware !!!
[ http://img.photobucket.com/albums/v472/JeffTT/1-22.jpg ]
[ http://img.photobucket.com/albums/v472/JeffTT/1a.jpg ]
[ http://img.photobucket.com/albums/v472/JeffTT/2-19.jpg ]
and another one to show it is common..
[ http://www.300zx.co.uk/forums/showthread.php?158950-Clutch-failure&highlight=clutch ]
