TwinTurbo.NET: Nissan 300ZX forum - Wheel bearing, outer tie rod, control arms
Subject Wheel bearing, outer tie rod, control arms
Posted by jonting421 on June 16, 2012 at 12:46 AM
Message Okay.
How do you inspect when a wheel bearing, outer tie rod, and control arm is going out?
I look around and I see wiggling the wheels different directions and stuff, but everywhere I see tells me something different.
How exactly do I check that the wheel bearing is bad.
How exactly do I check that the outer tie rod is bad.
How exactly do I check that the control arm is bad.
Also, if my control arm metal piece is not cracked or broken, I should be able to just replace the bushing yes?
Thanks a lot for the help.
Jon
