TwinTurbo.NET: Nissan 300ZX forum - None (IMHO) if the engine was only turned by hand.... (n/m)
jzack
on June 15, 2012 at 5:32 PM
Re: Re: Appears too tight. Not enough gap.
posted by hellraz0r1337
on June 15, 2012 at 03:58 PM
First time belt job
hellraz0r1337
10:10:30 06/15/12
Re: First time belt job
hellraz0r1337
10:20:57 06/15/12
Re: Re: First time belt job
hellraz0r1337
11:13:56 06/15/12
Should have 4mm after spinning it a few times.
Draker (Eugene, OR)
11:22:32 06/15/12
Re: Should have 4mm after spinning it a few times.
hellraz0r1337
11:33:48 06/15/12
Appears too tight. Not enough gap. (n/m)
Woody75 (Denver)
12:09:47 06/15/12
hellraz0r1337
12:24:40 06/15/12
hellraz0r1337
15:58:27 06/15/12
None (IMHO) if the engine was only turned by hand.... (n/m) -
jzack
17:32:22 06/15/12
None! Use make-shift tool that's 4mm thick 4 easy measuring. (n/m)
OverZealous (CT)
22:57:36 06/15/12
FYI: A 4mm hex key works nicely too. (n/m)
jzack
23:23:08 06/15/12
yep I do the same
aliaZ
10:15:12 06/17/12
Re: yep I do the same
hellraz0r1337
00:25:56 06/18/12
