| Subject |
Sequence is Pass Rear, Driver Rear, Pass Frt, Driver Frt, |
| Posted by |
Havoc300 (Chicago) on June 15, 2012 at 4:15 PM |
This message has been viewed 135 times. |
| In Reply To |
What is process and wheel sequence being used for >> posted by ZUL8TR on June 13, 2012 at 10:03 AM |
| Message |
Then the ABS Module. Basically, I pump the brake pedal, then open the bleed screw, and watch the fluid move through the clear tube, which is full of air bubbles (Front lines only). I also, left the bleed screw open while pumping the pedal trying to force the air out of the lines. Sometimes when I slowly press the pedal, and it gets relatively close to the floor, a quick surge of fluid and air runs through the tube as if I pressed the pedal rather suddenly. I am not loosing fluid from any leaks in the system. I have a considerable amount of air in it after the car sat over the winter.
| Follow Ups |
Post a Followup |
