TwinTurbo.NET: Nissan 300ZX forum - Should have 4mm after spinning it a few times.
Subject Should have 4mm after spinning it a few times.
Posted by Draker (Eugene, OR) on June 15, 2012 at 11:22 AM
  This message has been viewed 129 times.
In Reply To Re: Re: First time belt job posted by hellraz0r1337 on June 15, 2012 at 11:13 AM
Message It will take a bit to dial it in. Also, make sure you count the cogs on the belt from timing mark to timing mark. There is a spec for this in the FSM. It is the way you can be 100% sure you've got the belt on correctly.
The belt should not be rubbing on anything. Make sure you've got the belt guides installed on the crank sprocket. If in doubt post more pictures.
