TwinTurbo.NET: Nissan 300ZX forum - Re: If you suspect a head gasket leak,
Subject Re: If you suspect a head gasket leak,
Posted by Medallion Man on June 15, 2012 at 10:53 AM
  This message has been viewed 168 times.
In Reply To If you suspect a head gasket leak, posted by Audioquest on June 14, 2012 at 08:02 PM
Message have you done the EGR and plenum / TB water pipe delete?
if not there are some little pipes that could be causing that leak and you wouldn't see it if under pressure and temp as the water would evaporate....
as above get a few tests first to confirm not BHG...
are you getting any water in the cabin or fogged windscreen.. the water hoses for the heater matrix are also a problem point...
