TwinTurbo.NET: Nissan 300ZX forum - B4 pulling heads do all tests noted. With pressure test>>>
Subject B4 pulling heads do all tests noted. With pressure test>>>
Posted by ZUL8TR on June 14, 2012 at 7:29 AM
  This message has been viewed 198 times.
In Reply To Bubbles in coolant, not a head gasket?? posted by MaxxAction on June 13, 2012 at 05:16 PM
Message best to do stone cold to determine that pressure gage holds for some time (1 hr or greater ) at pumped pressure. Run test at 1.2 bar or about 18psi so that you do not over pressure the system. If test run hot the test pressure will lower in time as the fluid contracts during cooling down and thus give a leak misread on holding pressure for an extended time.
BTW I just tested the coolant voltage to ground with digital mm and it is 16.1 mv or 0.0161v (about 10 min to steady due to sensitivity). I would look for voltage leak into coolant system. Check all grounds, batt connections and clean as needed. Use dielectric grease B4 securing on all conections and batt posts and their cable clamps .
ZUL8TR in Orlando,FL
