TwinTurbo.NET: Nissan 300ZX forum - 2 things: Some say the coolant test is not absolute,
zellamay
on June 13, 2012 at 6:56 PM
Bubbles in coolant, not a head gasket??
posted by MaxxAction
on June 13, 2012 at 05:16 PM
so you could still have a bad h.g. (if they are right). Pressure test is next, as sandman said. Also, are you sure you've purged the system of all air to begin with?
MaxxAction
17:16:30 06/13/12
Have you pressure tested the system? (n/m)
sandmanz32
18:05:16 06/13/12
Re: Have you pressure tested the system?
MaxxAction
18:20:32 06/13/12
Um, it should have pressure not vacuum.
Draker (Eugene, OR)
18:54:23 06/13/12
Re: Um, it should have pressure not vacuum.
MaxxAction
18:59:39 06/13/12
its not a vacuum really
sandmanz32
21:18:36 06/13/12
When engine cools off pressure is reduced to atmospheric>>
ZUL8TR
06:46:01 06/14/12
2 things: Some say the coolant test is not absolute, -
zellamay
18:56:15 06/13/12
Re: 2 things: Some say the coolant test is not absolute,
MaxxAction
19:01:37 06/13/12
Re: Bubbles in coolant, not a head gasket??
MaxxAction
19:25:45 06/13/12
B4 pulling heads do all tests noted. With pressure test>>>
ZUL8TR
07:29:44 06/14/12
Here is a link on electrolysis. They note that 0.15v will>>
ZUL8TR
07:44:53 06/14/12
Re: Here is a link on electrolysis. They note that 0.15v will>>
MaxxAction
13:18:07 06/14/12
To correct negative reading on MM reverse probes>>
ZUL8TR
07:18:16 06/15/12
If you suspect a head gasket leak,
Audioquest
20:02:26 06/14/12
Re: If you suspect a head gasket leak,
Medallion Man
10:53:02 06/15/12
