TwinTurbo.NET: Nissan 300ZX forum - What is process and wheel sequence being used for >>
Subject What is process and wheel sequence being used for >>
Posted by ZUL8TR on June 13, 2012 at 10:03 AM
  This message has been viewed 190 times.
In Reply To 90NA Still have air in brake system... posted by Havoc300 (Chicago) on June 12, 2012 at 09:29 PM
Message bleeding? i.e. which item first to bleed and just using pedal pushing and zerk release?
Sounds like a leak somewhere.
Are all connections air tight?
Is the master leaking at the plunger that connects to the pedal? Might be hard to notice.
If you haven't you might try a pressure bleed or a gravity bleed.
ZUL8TR in Orlando,FL
