TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: clutch fork no longer attached to anything in the xmission
Subject Re: Re: Re: clutch fork no longer attached to anything in the xmission
Posted by Krazyd27(Houston) on June 13, 2012 at 9:08 AM
  This message has been viewed 347 times.
In Reply To Re: Re: clutch fork no longer attached to anything in the xmission posted by Wingman501 on June 12, 2012 at 05:00 PM
Message I believe there is another clip attached the throw out bearing on the input shaft, clipped to the top of the fork. I don't remember correctly but you should be able to pull the fork out and it'll be released from the top clip. when you re-install make sure you the top part of the fork is attached to the clip then attach the clutch fork to the pivot ball.
