TwinTurbo.NET: Nissan 300ZX forum - 90NA Still have air in brake system...
Subject 90NA Still have air in brake system...
Posted by Havoc300 (Chicago) on June 12, 2012 at 9:29 PM
  This message has been viewed 214 times.
Message So I bled the brakes again, along with the ABS Module. There is still a considerable amount of air in the front brakes. I've gone through a pint of fluid in the resevoir. When depressing the brake pedal, I can hear a slight hum and a kind of slurping sound at the Master Cylinder/Power Booster. When looking down in the resevoir while depressing the pedal, small bubbles can be seen at the rear of the resevoir near the brake booster. There is a slight rusting where the master cylinder and booster mount. There are no visible signs of leaks around the master cylinder. When the brake pedal is depressed there is very little pressure when the the car is idle or off.
Thanks,
