TwinTurbo.NET: Nissan 300ZX forum - If you go with the diesel oil try the Shell Rotella T5 10>>
Subject If you go with the diesel oil try the Shell Rotella T5 10>>
Posted by ZUL8TR on June 12, 2012 at 3:50 PM
  This message has been viewed 648 times.
In Reply To Re: You state the sound appears after warm up which >> posted by SammybTT(TN) on June 12, 2012 at 09:31 AM
Message 10w 30 it is also SM rated for gas engines. It is available at Walmart in a 5 qt jug. The 15w-40 is just to viscous. The deisel oils have extra clean additives that might help the lifter issue and/or other noise. Note that these oils are not Starburst (seal on front of bottle) rated by API. Not a problem they just can't pass the economy test and they probably exceed the ZDDP % in the standard gas engine oils with the Starburst symbol.
ZUL8TR in Orlando,FL
