TwinTurbo.NET: Nissan 300ZX forum - Re: Anyone have ARP stud torque specs?
Subject Re: Anyone have ARP stud torque specs?
Posted by Tech@EPR on June 12, 2012 at 6:37 AM
  This message has been viewed 937 times.
In Reply To Anyone have ARP stud torque specs? posted by coma_ass on June 11, 2012 at 01:40 PM
Message depends on which rod bolts/studs you have. If you are using aftermarket rods with ARP 2000 rod bolts typically its 45ftlbs with molly (Eagles/SCAT) and 50ftlbs with oil (Pauter)
Main studs - 75ftlbs w/ Moly
Head studs - (95ft lbs with oil on block end and moly on head end) Tq in 2 stages. Start at 50ftlbs and tq all the studs down. The again at 95ft lbs. Be sure to not bottom out the head studs in the deck, also you must retain the stock hardened head washers in conjunction with using the ARP washers as well. Ensure moly lube is coated on all wear surfaces (threads on studs and nuts, under and on top of washers)
Good luck
Ep Racing | Create Your Badge
