TwinTurbo.NET: Nissan 300ZX forum - Only disadvantage to testing them that way -- no
Subject Only disadvantage to testing them that way -- no
Posted by jzack on June 11, 2012 at 11:09 PM
  This message has been viewed 226 times.
In Reply To ok , i guess they're the smaller ones under the cover posted by jjames69 on June 11, 2012 at 09:47 PM
Message inspection of the injector contacts for corrosion (a common issue). If the injector wiring harness connector dust boots are cracked due to age - likely you see some issues. Testing thru the ECU connector may give bad readings even if the injector is still good.
If you test that way and all is good, great. For any issues found -- I'd check again at the injector.
