TwinTurbo.NET: Nissan 300ZX forum - Re: When I tried running Casterol in an old N/A I had, it
SammybTT(TN)
on June 11, 2012 at 6:19 PM
posted by 300ZMang
on June 11, 2012 at 12:20 PM
Yes the #1 injector is the loudest of all! I originally ran Mobil 1 but I didn't want to use that during the breaking in of this rebuild. thanks!
Engine noise (tick) videos to support June 3rd post
SammybTT(TN)
21:05:49 06/10/12
check your oil level. Run thicker oil. What are you running
mkhoid
21:23:36 06/10/12
Re: check your oil level. Run thicker oil. What are you running
SammybTT(TN)
21:51:40 06/10/12
300ZMang
12:20:36 06/11/12
Re: When I tried running Casterol in an old N/A I had, it -
SammybTT(TN)
18:19:24 06/11/12
Sounds like predominate sound is lifter related>>>>
ZUL8TR
09:11:48 06/11/12
Re: Sounds like predominate sound is lifter related>>>>
SammybTT(TN)
18:24:36 06/11/12
You state the sound appears after warm up which >>
ZUL8TR
08:01:51 06/12/12
Re: You state the sound appears after warm up which >>
SammybTT(TN)
09:31:52 06/12/12
If you go with the diesel oil try the Shell Rotella T5 10>>
ZUL8TR
15:50:06 06/12/12
Re: If you go with the diesel oil try the Shell Rotella T5 10>>
SammybTT(TN)
20:07:30 06/12/12
I have some experience with some of these oil cleaners. >>
ZUL8TR
09:52:40 06/13/12
Opps! It's Justice Brothers link inside>>>>..
ZUL8TR
12:41:00 06/13/12
Re: I have some experience with some of these oil cleaners. >>
SammybTT(TN)
18:25:02 06/14/12
Give the Rottela several hundred miles then report back>>
ZUL8TR
18:56:35 06/15/12
SammybTT(TN)
20:38:01 06/14/12
Do the compeassion test and report results. Leave the >>
ZUL8TR
16:00:27 06/17/12
Re: Do the compeassion test and report results. Leave the >>
SammybTT(TN)
12:06:54 06/18/12
Search here for the specifics on the leak down and what >>
ZUL8TR
15:52:06 06/20/12
