TwinTurbo.NET: Nissan 300ZX forum - Replace with OEM. Be sure to bleed properly. (n/m)
Summeronthechain (MN)
on June 08, 2012 at 12:58 PM
Re: Safety boost during hot days
posted by boostlv
on June 08, 2012 at 12:11 PM
boostlv
10:53:47 06/08/12
300ZMang
11:01:07 06/08/12
Re: Re: Safety boost during hot days
boostlv
11:43:15 06/08/12
how do you know you aren't overheating?
Ahmed (Chicago)
11:39:33 06/08/12
Re: how do you know you aren't overheating?
boostlv
11:44:15 06/08/12
there might not be any permanent damage yet
Ahmed (Chicago)
13:03:07 06/08/12
boostlv
12:11:14 06/08/12
Replace with OEM. Be sure to bleed properly. (n/m) -
12:58:47 06/08/12
This should be in the tech forum
spicyZ
12:50:30 06/08/12
Re: This should be in the tech forum
boostlv
13:52:43 06/08/12
ugh.. sounds like a disaster.
Antihero
16:44:52 06/11/12
Do you still have the stock soft rubber lower rad hose?
MixManMash
16:34:12 06/08/12
Re: Do you still have the stock soft rubber lower rad hose?
boostlv
17:36:30 06/08/12
No problem. I had the exact same issue and it only went
MixManMash
17:40:36 06/08/12
boostlv
17:37:21 06/08/12
How do I connect the reservoir with the radiator?
boostlv
17:45:21 06/08/12
It's an overflow tank. There is a small port on the
MixManMash
01:23:27 06/09/12
Fill out your profile. (n/m)
Gordo 93TT Daytona
21:38:03 06/08/12
