TwinTurbo.NET: Nissan 300ZX forum - curious as to how it's a night/day difference? seriuosly.
Subject curious as to how it's a night/day difference? seriuosly.
Posted by PiotrC70 on June 07, 2012 at 2:34 PM
  This message has been viewed 312 times.
In Reply To OP said with the engine in. Night/day difference. (n/m) posted by BigTDogg (MA) on June 07, 2012 at 02:09 PM
Message Even WITH the engine already in, you'd remove the radiator, fan, and shroud, as well as all TB piping and accordian pipes. With the bumper off, everything else should be easy to access with the exception of the turbo inlet pipes due to the PS pump and AC compressor.
The more I think about it, 20 or so hrs would probably right if you're counting starting from the beginning removing everything mentioned above + doing the install. I was simply counting JUST install time of the pipes.
1993 TT. R.I.P. 09.15.2010
