TwinTurbo.NET: Nissan 300ZX forum - Tape is NOT a good solution, but do what you want....
Subject Tape is NOT a good solution, but do what you want....
Posted by ZXoltan on June 07, 2012 at 12:15 PM
  This message has been viewed 177 times.
In Reply To This is essentially what the tape does... posted by white22sky on June 07, 2012 at 11:54 AM
Message Even with special "fine line" tape, you can only get so close to the edge. Wrapping tape under the lip is a sure way to have an thin line of unpainted perimeter around the trim (the thickness of the tape will leave a line) and makes it more likely you will have adhesion problems from insufficient sanding. You might be happy with the result, but it will look like a repaint every time. I dont recommend it.
