TwinTurbo.NET: Nissan 300ZX forum - Or where it is located so buried and surrounded by metal
jzack
on June 06, 2012 at 11:24 PM
Yes, I attached just a single wire. 2-wire set up = overkill
posted by OverZealous (CT)
on June 06, 2012 at 02:28 PM
that the problem is solved that way. Sensor line also doesn't run close to anything else in that location when traveling to the sensor module...
Knock Sensor / Detonation Sensor: How it Works & How to Test
OverZealous (CT)
00:11:01 06/05/12
Re: Knock Sensor / Detonation Sensor: How it Works & How to Test
Android300zx
09:45:44 06/05/12
Thanks! Good write up...
beanz
11:58:02 06/05/12
Re: Thanks! Good write up...
zromtech
13:01:14 06/05/12
Are you going to market the software you are working on? (n/m)
Evan_Wright (Ca)
14:20:26 06/05/12
Re: Are you going to market the software you are working on?
zromtech_
22:07:49 06/05/12
Why the 4400rpm limit?
beanz
14:56:02 06/05/12
It is certainly possible to detonate above 4400 rpm
OverZealous (CT)
22:11:09 06/05/12
Re: Why the 4400rpm limit?
zromtech_
22:52:45 06/05/12
Very informative
RobZ32
12:27:40 06/05/12
Good Layout, understandable presentation. Thank You. (n/m)
Gordo 93TT Daytona
12:49:33 06/05/12
Any comment on knock sensor relocation (n/m)
ZiNnYc
19:25:21 06/05/12
It's a great temporary solution -- fuzzymonkey squeak up!
OverZealous (CT)
22:01:55 06/05/12
From the picture included -- did you end up installing
jzack
23:20:15 06/05/12
OverZealous (CT)
14:28:18 06/06/12
Or where it is located so buried and surrounded by metal -
jzack
23:24:51 06/06/12
I believe the RF shielding is pretty important. See below.
OverZealous (CT)
21:45:11 06/07/12
Nice! I would like to clarify why only one side is grounded.
DVDBURN (MD)
23:20:40 06/06/12
Another link.
DVDBURN (MD)
23:42:53 06/06/12
Woah! So do NOT connect Terminal B to anything.
OverZealous (CT)
21:37:41 06/07/12
