TwinTurbo.NET: Nissan 300ZX forum - Nice! I would like to clarify why only one side is grounded.
Subject Nice! I would like to clarify why only one side is grounded.
Posted by DVDBURN (MD) on June 06, 2012 at 11:20 PM
  This message has been viewed 1135 times.
In Reply To Knock Sensor / Detonation Sensor: How it Works & How to Test posted by OverZealous (CT) on June 05, 2012 at 12:11 AM
Message The knock system circuit is a perfect example of an amplifying circuit with a signal caring cable in a high RF environment where you do not want a condition known as "ground loop".
Here is a link to a PDF file which explains how and what happens when there is a ground loop problem. Start at page 20 which precedes into the ground loop explanation.
[ http://www.sem.org/PDF/Szary_GroundLoopProblems.pdf ]
In this type of application (the knock circuit) grounding the shielded cable at both ends will cause a ground loop. In a ground loop circuit RF noise will be amplified causing unwanted signals in the line. Floating the cable at one end keeps the unwanted RF and higher currents out of the signal carrying line. As strange as it may sound it's true. I've dealt with this sort of problem as a tester in an EMI (electromagnetic interference testing) lab.
www.mytwinturbo.com
Nissan Data Voice on YouTube
Watch an ECZA meet caravan!
