TwinTurbo.NET: Nissan 300ZX forum - Seems like you've done all the right tests - would reach
Subject Seems like you've done all the right tests - would reach
Posted by jzack on June 06, 2012 at 11:18 PM
  This message has been viewed 287 times.
In Reply To AAC solenoid functional but not being controlled by ecu? posted by Evan_Wright (Ca) on June 06, 2012 at 04:02 PM
Message the same conclusion as you -- ECU driver has gone bad.
PS - Only other thing I can think to test, run a jumper line from the AAC over to the ECU connector and temporarily splice it in there. If the ECU to AAC solenoid wire has a small nick it may test out OK but not allow enough current to flow to trigger the solenoid to operate. This is a long shot -- last thing to test that comes to mind.
