TwinTurbo.NET: Nissan 300ZX forum - *Updated* with more info:
Subject *Updated* with more info:
Posted by Marshall on June 05, 2012 at 3:31 PM
  This message has been viewed 450 times.
In Reply To What can cause my car to stall at idle, only when cold? posted by Marshall on June 04, 2012 at 02:23 PM
Message I checked my AAC valve and I see that there is infinite resistance between the pins. It appears to be bad. Also, when I change the settings in Nissan Data Scan from one extreme to the other it makes no difference.
I was able to adjust the idle when it was warmed up using the screw, but as you can imagine it's not perfect with that bad AAC.
I got it running somewhat smoothly and I needed to do some test drives, but I needed to get the car inspected first. Unfortunately the car failed emissions.
Carbon Monoxide:
Allowable: 1.10
My result: 1.23
Hydrocarbons:
Allowable: 275
My result: 390
Oxides of Nitrogen:
Allowable: 3600
My result: 6450
RPM: 1597
Dilution: 15.8%
Is it even possible for my car to pass with no AIVs, no EGR, and a SZ high flow cat? Who can I take my Z to in the Philly area to get it inspected? Hopefully it just needs some minor work.
