TwinTurbo.NET: Nissan 300ZX forum - Re: And also wont require a plenum pull to change
SammybTT(TN)
on June 04, 2012 at 6:22 PM
posted by ZXoltan
on June 04, 2012 at 04:05 PM
That is would be a bonus. I will look at the VTC items when I get home tonight. I am also thinking about removing one quart of oil and replacing with Lucas oil additive.
Noisy hydraulic lifter help after rebuild
SammybTT(TN)
10:23:58 06/03/12
Are you sure it's not the VTC Springs instead? (n/m)
ZTicket(Dallas)
13:30:29 06/03/12
Re: Are you sure it's not the VTC Springs instead?
SammybTT(TN)
20:26:10 06/03/12
Did you replace the intake cam gears with BDE's or new ones? (n/m)
ZXoltan
04:45:40 06/04/12
Re: Did you replace the intake cam gears with BDE's or new ones?
SammybTT(TN)
09:14:22 06/04/12
Re: Re: Did you replace the intake cam gears with BDE's or new ones?
SammybTT(TN)
09:19:51 06/04/12
ZXoltan
16:05:19 06/04/12
Re: And also wont require a plenum pull to change -
SammybTT(TN)
18:22:37 06/04/12
Re: Re: And also wont require a plenum pull to change
SammybTT(TN)
21:27:32 06/04/12
Re: Re: Re: And also wont require a plenum pull to change
SammybTT(TN)
21:43:22 06/05/12
SammybTT(TN)
22:47:44 06/05/12
Re: Re: Re: Re: And also wont require a plenum pull to change
SammybTT(TN)
19:41:34 06/10/12
SammybTT(TN)
20:35:09 06/10/12
Re: Re: Re: Did you replace the intake cam gears with BDE's or new ones?
SammybTT(TN)
22:10:31 06/06/12
Re: Re: Re: Re: Did you replace the intake cam gears with BDE's or new ones?
SammybTT(TN)
21:45:36 06/07/12
I would think a side by side comparison with a stethoscope
ZTicket(Dallas)
06:13:11 06/04/12
Re: I would think a side by side comparison with a stethoscope
SammybTT(TN)
09:15:21 06/04/12
Hope u get it figured out. Please report back when you do... (n/m)
ZXoltan
20:14:06 06/03/12
Re: Hope u get it figured out. Please report back when you do...
SammybTT(TN)
09:16:36 06/04/12
