TwinTurbo.NET: Nissan 300ZX forum - What can cause my car to stall at idle, only when cold?
Subject What can cause my car to stall at idle, only when cold?
Posted by Marshall on June 04, 2012 at 2:23 PM
  This message has been viewed 1250 times.
Message I'm still working out the bugs in my car, and the problem I'm trying to solve now involves the idle.
When I start the car when it's cold, it won't idle. I have to keep my foot on the gas or else it stalls immediately. Once the car warms up it's able to hold an idle, around 600 rpm. It seems to drive fine.
I hooked up Nissan Data Scan to look at the sensor values to see what it's doing. Here are some details:
Test Results
LabelEngine OffRunning ColdWarmed Up
RPM0425-825600
Airflow0.571.040.95
Throttle0.38-0.40.38-0.40.38-0.4
Water Temp75.280174.2
Fuel Temp71.67277
AAC Valve07148-62
Timing161615
O2??7-80
O2 RH??7-80
A/F Base10010097-107
1991 TT
Sport 550 turbos
615cc injectors
SZ ECU for a 91 5 speed with 615cc injectors and dual pop
Selin MAF translator
EGR deleted
AIV deleted
