TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Re: Why would you pull the crank pulley to do the water pump?
Subject Re: Re: Re: Re: Why would you pull the crank pulley to do the water pump?
Posted by Lets_Go_Blues on June 04, 2012 at 12:54 PM
  This message has been viewed 139 times.
In Reply To Re: Re: Re: Why would you pull the crank pulley to do the water pump? posted by Aldrand on June 04, 2012 at 10:39 AM
Message If you were in that deep and noticed the timing belt was damage then you probably should have replaced it. Irregardless, if your timing marks all line up then your good on that end. Even being off a few teeth it will still run just poorly. I would check ur cas and pt wiring. If your alternator was dead it should still start with a jump but die shortly after..
