TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Why would you pull the crank pulley to do the water pump?
Subject Re: Re: Re: Why would you pull the crank pulley to do the water pump?
Posted by Aldrand on June 04, 2012 at 10:39 AM
  This message has been viewed 157 times.
In Reply To Re: Re: Why would you pull the crank pulley to do the water pump? posted by Lets_Go_Blues on June 03, 2012 at 08:15 PM
Message Well that is true. And probably so lol. I did notice my brand new timing belt had been rubbing somewhere on the outside edge though. I thought I had straightened out the cover enough to stop that but apparently not. Could it possibly be rubbing enough to slow the timing causing it to die shortly after start, and also causing the burning smell?? Or on second thought, could the alternator have gone out somehow considering the water pump belt also goes to it. Fuses are good, all wires and connectors are unharmed.. shit I just don't know.
