TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Why would you pull the crank pulley to do the water pump?
Subject Re: Re: Why would you pull the crank pulley to do the water pump?
Posted by Lets_Go_Blues on June 03, 2012 at 8:15 PM
  This message has been viewed 139 times.
In Reply To Re: Why would you pull the crank pulley to do the water pump? posted by Aldrand on June 03, 2012 at 02:46 PM
Message The crank pulley only lines up one way so as long as you didn't mess with the timing belt then that has nothing to do with it. I would bet that the burning smell is bad lol and probably your problem. Find out what is burning and fix it. Check all your fuses and grounds.
