TwinTurbo.NET: Nissan 300ZX forum - Power antenna / remote would be for an external amp
Subject Power antenna / remote would be for an external amp
Posted by JBender on June 02, 2012 at 6:53 PM
  This message has been viewed 325 times.
In Reply To Installing new navigation/stereo head unit posted by MITTZX on June 02, 2012 at 05:29 PM
Message If you have an external speaker amplifier (or sub + amp), you would use the dark blue 'Power antenna / remote' wire. It provides +12V when the headunit is on to tell those other amps to turn on. The light blue 'Power antenna' wire does the same thing except only when the radio is selected on the headunit.
RTFSM - Read the Factory Service Manual
Purpose of site is to archive Z information. It is found by using search. Same reason you go to a library to read books to research a topic instead of standing in the library lobby shouting your question hoping someone has read the books your answer is in. - LordZ
Hi guys, my mechanic died before finish my car so i try to finish myself - ktranne
