TwinTurbo.NET: Nissan 300ZX forum - A/F alpha at idle is 109 but wideband is rich. Confused.
Subject A/F alpha at idle is 109 but wideband is rich. Confused.
Posted by treese88 on June 01, 2012 at 8:56 PM
  This message has been viewed 1315 times.
Message From what I understand if A/F alpha is above 100 that means there is a lean condition and the ecu has to adjust and add fuel. Which makes these readings seem to contradict eachother. As far as I can tell I am rich at idle so a/f alpha should be 100 or less.
Idle:
Both my o2's stick around .8v and do not bounce. A/F alpha is 109 on both sides. Wideband afr is ~13.2.
Idle with a/c on:
o2's drop to like .1v, a/f alpha 100 both sides. wideband 14.5. My idle is smoother with the a/c on.
Cruising:
~14.5 a/f, bouncing o2's, alpha I haven't checked.
So...what is going on here? Please school me.
'91 TT
