TwinTurbo.NET: Nissan 300ZX forum - Use a socket without a shoulder inside it
Subject Use a socket without a shoulder inside it
Posted by Joe@ZSpeedperformance on June 01, 2012 at 12:01 PM
  This message has been viewed 122 times.
In Reply To Few Questions..... posted by 300ZMang on June 01, 2012 at 09:25 AM
Message and an extension.
Check pad contact areas on calipers, if they are grooved in it will cause noise, There should be tiny little metal shims under the pads between the calipers contact and pad contact areas. Also check front rotors for warpage.
Check fuel pressure, TPS settings,Temp sensor, O2 sensors, Injectors.
