TwinTurbo.NET: Nissan 300ZX forum - Re: Short answer: no
Subject Re: Short answer: no
Posted by Medallion Man on June 01, 2012 at 10:23 AM
  This message has been viewed 116 times.
In Reply To Short answer: no posted by spicyZ on June 01, 2012 at 09:19 AM
Message That is such a common symptom over here in the UK.
mostly caused my corrosion on connectors, so check all connectors, MAF, CAS, TPS, PTU ...etc.... make sure they are clean and connection properly.
check the TPS voltage, check the timing (with a timing light, 15 off TDC).
also try disconnection the MAF and if not that the O2's (lambda sensors) ..... look in the tech section for help on these checks...
