TwinTurbo.NET: Nissan 300ZX forum - Few Questions.....
Subject Few Questions.....
Posted by 300ZMang on June 01, 2012 at 9:25 AM
  This message has been viewed 135 times.
Message 1. What do you guys use to change the Engine Temp Sensor? Seems like a 19mm socket won't fit over the plastic portion of the sensor and it's in an awkward spot to attempt to use a wrench (without removing fan shroud).
2. Front brakes are clicking/crunching badly, even if I'm not moving and I press my brake pedal. Is this because of old shims or do I possibly have other issues?
3. What specific items to check when experiencing a stumble at certain RPM's? My car does it around the 2k RPM range up to 3k or so, on very light throttle. Doesn't matter if I start the car cold, or hot, it will be this way for a the first few minutes of driving then smooth out.
THANKS
