TwinTurbo.NET: Nissan 300ZX forum - Re: Once warmed up the coolant temp sensor OHM's in at
Subject Re: Once warmed up the coolant temp sensor OHM's in at
Posted by MaxxAction on June 01, 2012 at 7:19 AM
  This message has been viewed 236 times.
In Reply To Once warmed up the coolant temp sensor OHM's in at posted by Coldfusown on May 31, 2012 at 11:57 PM
Message fully warmed up...
you should only see about 300-330 ohms resistance. If what you say is true, your car is reading that it is only warmed toa about 130 degrees.
Not revving past 2200 RPM is a very classic symptom of a bad maf.
