TwinTurbo.NET: Nissan 300ZX forum - Re: I'm having problems getting my Koyo radiator in position!!!!
Subject Re: I'm having problems getting my Koyo radiator in position!!!!
Posted by MaxxAction on May 31, 2012 at 7:22 PM
  This message has been viewed 160 times.
In Reply To I'm having problems getting my Koyo radiator in position!!!! posted by Markz (Tampa) on May 31, 2012 at 07:10 PM
Message If you still have stock IC piping...
loosen the bolts that hold the pipes in place and let them relax a little bit.
Also, one of the things I did with the enormous Megan radiator i put in my car which also has 2.5 inch IC piping, was cut a notch out of the front of the insulators that go under the radiator so I could install it moving it towards the front of the car, not from the top down. When I take it out and put it back, I slide the pins in, and tilt it up to force it in between the pipes. Makes it a lot easier.
