TwinTurbo.NET: Nissan 300ZX forum - Re: I relocated PTU and am using the loop as well.
Subject Re: I relocated PTU and am using the loop as well.
Posted by MaxxAction on May 31, 2012 at 11:36 PM
  This message has been viewed 151 times.
In Reply To I relocated PTU and am using the loop as well. posted by Coldfusown on May 31, 2012 at 11:18 PM
Message While you're at it....
check the resistance on your coolant temp sensor. I was doing a recording on datascan last night, and my CTS was read 202 degrees! I freaked out, even though the gauge showed normal, but calmed down quickly, and changed the sensor, and it dropped from 202 at idle to 178.7
If the sensor is reading that the car is really hot, the ECU is going to reduce the timing, and richen up the mixture in an effort to try to cool the motor down.
