TwinTurbo.NET: Nissan 300ZX forum - Re: To add:
Subject Re: To add:
Posted by MaxxAction on May 31, 2012 at 10:57 PM
  This message has been viewed 248 times.
In Reply To To add: posted by Coldfusown on May 31, 2012 at 08:40 PM
Message First...
where are you reading the timing? I used to be able to get an accurate reading off the loop, but since I relocated the PTU, I have to remove the number one coil and use a plug wire to get an accurate reading.
IF that is all good, try another cas. I read more and more posts and threads about CAS issues recently, in addition to having a lot of problems getting a CAS that actually works right. See here:
http://www.twinturbo.net/nissan/300zx/forums/technical/view/1125756/Cant-I-get-a-CAS-that-actually-works.html
