TwinTurbo.NET: Nissan 300ZX forum - He needs the window down to remove the cover
Subject He needs the window down to remove the cover
Posted by white22sky on May 31, 2012 at 7:51 AM
  This message has been viewed 145 times.
In Reply To passenger window in a 93 TT won't go up or down posted by ZBeast29 on May 30, 2012 at 08:29 PM
Message that is behind the glass on the door pillar. I assume the window does not work from the drivers switch or the passenger switch. Do you hear any noise from the door when
the switch is pushed? You can sometimes if your very careful remove the door panel enough to get at the screws and bracket which are under the pillar cover without removing the pillar cover. I dont like doing it this way but if you're in a pinch. Others may chime in with what they've done.
" I told my son, you have to catch the football other wise this just
looks like child abuse." - My brother
