TwinTurbo.NET: Nissan 300ZX forum - Starting Z with gas in oil?
Jinjiro
on May 30, 2012 at 8:35 PM
I had a gas leak due to bad o-rings. Do I need to change the oil before starting it, or is it ok to start it and check for leaks, and then change the oil?
Starting Z with gas in oil? -
Jinjiro
20:35:45 05/30/12
Change your oil right away when ever there is any type of
JoshE300zxTT
21:16:26 05/30/12
good choice Jinjiro! hope you find the problem!
JoshE300zxTT
19:12:33 06/01/12
JoshE300zxTT
19:12:33 06/01/12
HOw long did you drive w/ leaking O-ring(s)? It depends >>
Gordo 93TT Daytona
20:25:56 05/31/12
I didn't drive it at all, only started it up for maybe 5-10
Jinjiro
08:28:32 06/01/12
Gas will normally float on top.
Wingzerro93
09:20:32 06/01/12
Thanks! I'm going to run some cheaper oil in it until I make
Jinjiro
09:37:38 06/01/12
