TwinTurbo.NET: Nissan 300ZX forum - under full accell boost gauge should be at least above zero.
Subject under full accell boost gauge should be at least above zero.
Posted by nemo1080 (Iowa) on May 29, 2012 at 10:53 PM
  This message has been viewed 153 times.
In Reply To 85 300zx gauges posted by Eishiba on May 26, 2012 at 11:51 PM
Message if it is not you could have a boost leak, bad turbo or a bunch of other problems. The other gauge is for your oil. The top is oil temp the bottom is oil pressure. If it does not work check your sending unit under the hood or maybe your fuses. I am not that well versed with the older Z's as this website is for the 90-96 Z32's and not your Z31. Check you 300zxclub.com they may be able to help you further.
It's not turbo lag, It's foreplay! Click Sig for My local forum!
" A Z was stolen But apparently to everyone here it's more important that the D key is not to the E key and she missed.
Do you people have souls? Seriously, this is pretty fucked up."
- Pacmanpth
